Hello @Bob_NXP_user
I hope you are doing very well.
Yes, you can use the same PHY address (e.g. 0x0) on both Ethernet PHYs in i.MX93, as long as each is connected to its own MDIO bus (separate MDC/MDIO lines). The addresses only need to be unique per bus, not across the whole system.
For good practice, it is recommended to use different PHY addresses, but not really necessary in this case.
Salas.
