SW setting for wakeup from standby mode by ONOFF button
3,506件の閲覧回数
ko-hey
Senior Contributor II
Hi all
I and my customer want to wake up from standby mode by ONOFF button.
I talked about it in following thread and guess I need something for make any unmasked interrupt by ONOFF behavior.
Function of PWR_BTN_SNS in SABRE-SDP
How to wakeup by PMIC_STBY_REQ
Do we have any SW setting for operating by ONOFF button ?
Unfortunately, our Linux version is very old (3.0.35), so if you are not have the same version you can use a different version of the reference.
Ko-hey
5 返答(返信)
3,002件の閲覧回数
Hi Ko-hey
please check
imx6 ONOFF button can make a interrupt to arm core.
[5/7] input: keyboard: imx: add snvs power key driver - Patchwork
and attached Linux Manual sect.2.2 Interrupts (Operation).
3,002件の閲覧回数
ko-hey
Hi igorpadykov
Thank you for reply.
Do you have any patch for 3.0.35 ?
Ko-hey
3,002件の閲覧回数
Hi Ko-hey
no
3,002件の閲覧回数
ko-hey
Hi igorpadykov
Okay, so which source file do we modify in 3.0.35 ?
Ko-hey
3,002件の閲覧回数
Hi Ko-hey
please again check
" snvs power key driver. It work in imx chips after i.mx6sx ON/OFF key used power on/off whole system. This driver make it wakeup from suspend state when short press ON/OFF key."
does it meet your needs ?
and attached in previous answer Linux Manual sect.2.2 Interrupts (Operation) .
