SSD enumerates at Gen 1 link speed after wake up from S3 sleep
668件の閲覧回数
GauravSinha
Using iMX8QM and I am trying the below sequence
  1. Power on the SSD (connected using key to key M convertor).
  2. Check link speed to be Gen3
  3. Put system to sleep say for 30 to 40susing rtcwake -m mem -s <sleep duration>
  4. Check link speed to be Gen3 once system wakes up --> Error observed link speed drops to Gen 1
  5. Repeat step 3 to 4.
I tested multiple SSDs and all of them reported Gen 1 link speed. The issue is recreated faster using L5.4.70_2.3.0_IMX8QM and L5.10.72_2.2.0_IMX8QM images at the link "https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat.... I have tried the test on two IMX8QM boards and I am able to recreate the issue.
Could you please help to identify if it is an issue with OS.
2 返答(返信)
647件の閲覧回数
Yuri
@GauravSinha
Hello
  I've sent You some comments directly.
Yuri.
638件の閲覧回数
GauravSinha
Hi @Yuri
Thanks for your feedback. I have received your mail.
I will share you the requested logs. Please expect some delay.
Gaurav
