SRKH register key values for i.MX6 & i.MX8
jbhaijy
Dear Experts,
We have SRKH register key values setup for i.MX6. Now we are migrating from i.MX6 to i.MX8, so can we use the same values that we use for the i.MX6?
Yunus
jbhaijy
Any update on above query?
Sanket_Parekh
Hi @jbhaijy
I hope you are doing well
=> No, We will recommend you to use the new value for that board.
Thanks & Regards
Sanket Parekh
jbhaijy
Hi Sanket,
Thanks for response.
May I know the reason why we cannot use the same SRKH key value for i.MX8? Is there any SoC specific reason? Please provide some more info.
Sanket_Parekh
Hi @jbhaijy
I hope you are doing well.
As both the boards have many architecture wise differences and NXP can not recommend with the same efuses as it is one time programmable.
One can refer to the section . 1.7 Programming SRK Hash of document root/doc/imx/habv4/guides/mx8m_mx8mm_secure_boot.txt
"Be careful when programming these values, as this data is the basis for the root of trust. An error in SRK Hash results in a part that does not boot."
Thanks & Regards
Sanket Parekh
