SPI ioctl hangs in imx6ul
1,048 次查看
obulesu_veggidi
sometimes spi ioctl in imx6ul hangs indefinitely.
ioctl(sSpiObj.spiFd, SPI_IOC_MESSAGE(1), &sSpiTransfer);
What could be the reason, is the issue belongs to the driver or SPI config in dts file?
标记 (1)
4 回复数
1,019 次查看
Bio_TICFSL
 The as example:
struct spi_ioc_transfer tr[256];
has to be defined as a global variable.
995 次查看
obulesu_veggidi
Hello Bio_TICFSL,
I made it as a global variable, still the problem exist.
Do I need to change SPI config in dts?
983 次查看
Bio_TICFSL
Hi, You said it happens sometimes, this should be a problem of the hardware you have connected.
971 次查看
obulesu_veggidi
Hello Bio_TICFSL,
We have interfaced CLRC663 chip which is a NXP contactless card reader chip.
