Seeing that ENET_RXD0 is used as SPDIF_OUT, I am a bit confused whether I can design the board using Ethernet and SPDIF at the same time.
If that is the case what should I take into consideration during the HW design.
Thanks in advance,
Mete
Solved! Go to Solution.
Just figured out that ENET_RX_DATA0 is of MII/RMII interface and I will be using RGMII which has a different interface and related pin is named RGMII_RD0.
I believe this is the answer to my question.
