SNVS i.MX8M Plus LPDDR4 EVK
Jimmychea
How to enter the SNVS mode for the i.MX8M Plus LPDDR4 EVK ?
Labels (2)
riteshmpatel
Hi @Jimmychea,
I hope you are doing well.
Please use "poweroff" command to enter into the SNVS mode.
Thanks & Regards,
Ritesh M Patel
Jimmychea
After entering "poweroff" command, how to verify it is in SNVS mode ?
riteshmpatel
Hi @Jimmychea,
One can refer to Figure 5. SNVS mode ON/OFF sequence of the PMIC datasheet. One can measure the respective voltage as per Figure 5 in the EVK.
Thanks & Regards,
Ritesh M Patel
