SN65DSI86 bridge connection issue with MIPI_DSI
472件の閲覧回数
Cyriactoms
Mipi dsi not able to attach the sn65dsi bridge. The driver is loading fine but it gives an error like this   [ 7.223851] [drm:drm_bridge_attach] *ERROR* failed to attach bridge /soc@0/bus@32c00000/mipi_dsi@32e60000 to encoder DSI-40: -19
[ 7.240955] imx_sec_dsim_drv 32e60000.mipi_dsi: Failed to attach bridge: 32e60000.mipi_dsi
[ 7.249236] DSIM_DEBUG: sec_mipi_dsim_bind() returned -19
[ 7.261771] imx_sec_dsim_drv 32e60000.mipi_dsi: failed to bind sec dsim bridge: -19
[ 7.269436] imx-drm display-subsystem: bound 32e60000.mipi_dsi (ops imx_sec_dsim_ops)
vcc_1v2: regulator-vcc-1v2 {
compatible = "regulator-fixed";
regulator-name = "vcc_1v2";
regulator-min-microvolt = <1200000>;
regulator-max-microvolt = <1200000>;
regulator-always-on;
regulator-boot-on;
vcc_1v8: regulator-vcc-1v8 {
regulator-name = "vcc_1v8";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
regulator-boot-on;
panel_edp: panel {
compatible = "lg,lp079qx1-sp0v";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_mipi_dsi_en>;
status = "okay";
port {
panel_in: endpoint {
remote-endpoint = <&edp_bridge_out>;
display-timings {
native-mode = <&timing_1280x800>;
timing_1280x800: 1280x800 {
clock-frequency = <77000000>; /* 77.00 MHz */
hactive = <1280>;
vactive = <800>;
hfront-porch = <160>;
hsync-len = <32>;
hback-porch = <40>; /* Calculated: 232 - 160 - 32 */
vfront-porch = <20>;
vsync-len = <6>;
vback-porch = <30>; /* Calculated: 56 - 20 - 6 */
refclk: input_refclk{
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <19200000>;
clock-output-names = "refclk";
&lcdif1 {
status = "okay";
lcdif1_disp: port@0 {
reg = <0>;
lcdif_to_dsim_1: endpoint {
remote-endpoint = <&dsim_from_lcdif_2>;
&mipi_dsi {
status = "okay";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
dsim_from_lcdif_2: endpoint {
remote-endpoint = <&lcdif_to_dsim_1>;
port@1 {
reg = <1>;
dsim_to_edpbridge: endpoint {
remote-endpoint = <&edp_bridge_in>;
&i2c3{
clock-frequency = <400000>;
pinctrl-0 = <&pinctrl_i2c3>;
status = "okay";
sn65dsi86_bridge: sn65dsi86@2c{
compatible = "ti,sn65dsi86";
reg = <0x2c>;
status ="okay";
pinctrl-0 = <&pinctrl_dp>;
enable-gpios = <&gpio1 5 GPIO_ACTIVE_HIGH>;
vccio-supply = <&vcc_1v8>;
vpll-supply = <&vcc_1v8>;
vcca-supply = <&vcc_1v2>;
vcc-supply = <&vcc_1v2>;
clock-names = "refclk";
clocks = <&refclk>;
ports{
#size-cells = <0>;
port@0 {
reg = <0>;
edp_bridge_in: endpoint {
remote-endpoint = <&dsim_to_edpbridge>;
data-lanes = <0 1 2 3>;
port@1 {
reg = <1>;
edp_bridge_out: endpoint {
remote-endpoint = <&panel_in>;
Does it work with i2c when i tried i2cdump its giving xx values for every register and also
cat /sys/kernel/debug/regmap/2-002c/registers giving xx values is this the cause for the mipi dsi to bind
タグ(1)
414件の閲覧回数
Bio_TICFSL
What the regulator do? if marked the fails on regulator but I can not tested since we have no SN65DSI at hand, you should try to change this.
%3CLINGO-SUB%20id%3D%22lingo-sub-2160563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMIPI_DSI%20%E3%81%AB%E3%82%88%E3%82%8B%20SN65DSI86%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E6%8E%A5%E7%B6%9A%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2160563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMipi%20dsi%20%E3%81%AF%20sn65dsi%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%20%5B%207.223851%5D%20%5Bdrm%3Adrm_bridge_attach%5D%20*ERROR*%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%20%2Fsoc%400%2Fbus%4032c00000%2Fmipi_dsi%4032e60000%20%E3%82%92%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%20DSI-40%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3A%20-19%3CBR%20%2F%3E%20%5B%207.240955%5D%20imx_sec_dsim_drv%2032e60000.mipi_dsi%3A%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%2032e60000.mipi_dsi%3CBR%20%2F%3E%5B%207.249236%5D%20DSIM_DEBUG%3A%20sec_mipi_dsim_bind()%20%E3%81%8C%20-19%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%207.261771%5D%20imx_sec_dsim_drv%2032e60000.mipi_dsi%3Asec%20dsim%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%81%AE%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20-19%3CBR%20%2F%3E%20%5B%207.269436%5D%20imx-drm%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%3A%2032e60000.mipi_dsi%20%E3%82%92%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%EF%BC%88%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20imx_sec_dsim_ops%EF%BC%89%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Evcc_1v2%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%3CSPAN%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF-vcc-1v2%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22regulator-fixed%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E5%90%8D%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22vcc_1v2%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E6%9C%80%E5%B0%8F%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%83%9C%E3%83%AB%E3%83%88%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E1200000%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E6%9C%80%E5%A4%A7%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%83%9C%E3%83%AB%E3%83%88%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E1200000%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E5%B8%B8%E6%99%82%E3%82%AA%E3%83%B3%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%96%E3%83%BC%E3%83%88%E3%82%AA%E3%83%B3%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Evcc_1v8%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%3CSPAN%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF-vcc-1v8%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22regulator-fixed%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E5%90%8D%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22vcc_1v8%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E6%9C%80%E5%B0%8F%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%83%9C%E3%83%AB%E3%83%88%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E1800000%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E6%9C%80%E5%A4%A7%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%83%9C%E3%83%AB%E3%83%88%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E1800000%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E5%B8%B8%E6%99%82%E3%82%AA%E3%83%B3%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%96%E3%83%BC%E3%83%88%E3%82%AA%E3%83%B3%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Epanel_edp%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%3CSPAN%3E%E3%83%91%E3%83%8D%E3%83%AB%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22lg%2Clp079qx1-sp0v%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epinctrl-names%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22default%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epinctrl-0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bpinctrl_mipi_dsi_en%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22%E6%AD%A3%E5%B8%B8%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epanel_in%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bedp_bridge_out%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E8%A1%A8%E7%A4%BA%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Btiming_1280x800%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0_1280x800%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3E1280x800%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E77000000%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%2077.00%20MHz%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ehactive%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E1280%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Evactive%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E800%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Ehfront-porch%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E160%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ehsync-len%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E32%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ehback-porch%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E40%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E8%A8%88%E7%AE%97%E7%B5%90%E6%9E%9C%3A%20232%20-%20160%20-%2032%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Evfront-porch%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E20%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Evsync-len%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E6%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Evback-porch%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E30%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E8%A8%88%E7%AE%97%E7%B5%90%E6%9E%9C%3A%2056%20-%2020%20-%206%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E5%8F%82%E7%85%A7%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3C%2FSPAN%3E%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3Einput_refclk%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22%E5%9B%BA%E5%AE%9A%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BB%E3%83%AB%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E19200000%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%87%BA%E5%8A%9B%E5%90%8D%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22refclk%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%26amp%3Blcdif1%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22%E6%AD%A3%E5%B8%B8%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Elcdif1_disp%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%3CSPAN%3E%E3%83%9D%E3%83%BC%E3%83%88%400%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Elcdif_to_dsim_1%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bdsim_from_lcdif_2%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26amp%3Bmipi_dsi%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22%E6%AD%A3%E5%B8%B8%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%BB%E3%83%AB%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23size-cells%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%9D%E3%83%BC%E3%83%88%400%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edsim_from_lcdif_2%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Blcdif_to_dsim_1%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%9D%E3%83%BC%E3%83%88%401%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edsim_to_edpbridge%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bedp_bridge_in%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26amp%3Bi2c3%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E400000%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epinctrl-names%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22default%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epinctrl-0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bpinctrl_i2c3%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22%E6%AD%A3%E5%B8%B8%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Esn65dsi86_bridge%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%20%3CSPAN%3Esn65dsi86%402c%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22ti%2Csn65dsi86%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E0x2c%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22%E6%AD%A3%E5%B8%B8%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Epinctrl-names%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22default%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Epinctrl-0%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bpinctrl_dp%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Eenable-gpios%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bgpio1%3C%2FSPAN%3E%20%3CSPAN%3E5%3C%2FSPAN%3E%20%3CSPAN%3EGPIO_ACTIVE_HIGH%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Evccio-%E9%9B%BB%E6%BA%90%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bvcc_1v8%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Evpll-%E9%9B%BB%E6%BA%90%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bvcc_1v8%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Evcca-%E4%BE%9B%E7%B5%A6%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bvcc_1v2%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Evcc-%E9%9B%BB%E6%BA%90%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bvcc_1v2%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%90%8D%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22refclk%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Brefclk%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%BB%E3%83%AB%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23size-cells%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%9D%E3%83%BC%E3%83%88%400%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Eedp_bridge_in%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bdsim_to_edpbridge%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%B3%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%9D%E3%83%BC%E3%83%88%401%3C%2FSPAN%3E%20%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Eedp_bridge_out%3C%2FSPAN%3E%20%3CSPAN%3E%3A%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3Bpanel_in%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%B3%20%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E2%3C%2FSPAN%3E%20%3CSPAN%3E3%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ei2c%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9Fi2cdump%E3%82%92%E8%A9%A6%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%ABxx%E3%81%AE%E5%80%A4%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecat%20%2Fsys%2Fkernel%2Fdebug%2Fregmap%2F2-002c%2Fregisters%20xx%20%E3%81%AE%E5%80%A4%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%20mipi%20dsi%20%E3%81%8C%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%81%95%E3%82%8C%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2160563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SN65DSI86%20bridge%20connection%20issue%20with%20MIPI_DSI%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AF%E4%BD%95%E3%82%92%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AB%E9%9A%9C%E5%AE%B3%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8C%E3%80%81%E6%89%8B%E5%85%83%E3%81%AB%20SN65DSI%20%E3%81%8C%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
