SECO(Security Controller) function in i.MX8XLite with Industrial chip-set
1,565 次查看
deega_jung
Dear NXP Support Team,
Please help me with my inquiry.
i.MX8XLite Automotive Chip-set can chose a 3-kind of function which are Non-Secure, V2X/SECO and SECO. But Industrial Chip-set can not chose security function option.
Does the industrial chip-set include the SECO option by default include?
Deega Jung
1,458 次查看
Sanket_Parekh
Hello @deega_jung,
I hope you are doing well.
I'm glad my suggestion helps you.
If the query is solved now, Can I mark this case as closed?
Thanks & Regards,
Sanket Parekh
1,512 次查看
Sanket_Parekh
Hello @deega_jung,
->It should work, Since SECO is the whole security block unless one selects the "non-secure one" it should be included.
I hope it helps!
Thanks & Regards,
Sanket Parekh
1,479 次查看
deega_jung
Hello Sanket Parekh,
Thank you for your reply.
I'm very helpful from your comment.
Deega Jung
1,459 次查看
Sanket_Parekh
Hello @deega_jung,
Thanks & Regards,
Sanket Parekh
