SDXC in MCIMX6X4CVM08AC
2,026件の閲覧回数
sowmiya_a
MCIMX6X4CVM08AC - Will this part supports 128gb sd card (SDXC)?
Please reply asap
7 返答(返信)
2,020件の閲覧回数
riteshmpatel
Hi @sowmiya_a,
I hope you are doing well.
Kindly refer to Table 2. i.MX 6SoloX Modules List of i.MX6 Solo X datasheet. It mentions that the processor supports SDHC cards up to 32GB.
Thanks & Regards,
Ritesh M Patel
2,015件の閲覧回数
riteshmpatel
Hi @sowmiya_a,
It does support SDXC as well.
Thanks & Regards,
Ritesh M Patel
2,011件の閲覧回数
sowmiya_a
Based on your response, I understand that MCIMX6X4CVM08AC can support 128 GB of SD card (SDXC). Am i right?
2,006件の閲覧回数
riteshmpatel
Hi @sowmiya_a,
Yes. That is correct.
Thanks & Regards,
Ritesh M Patel
1,991件の閲覧回数
sowmiya_a
Can you confirm whether the part (MCIMX6X4CVM08AC) can support exFAT file system?
1,984件の閲覧回数
riteshmpatel
Hi @sowmiya_a,
SDXC standard supports a capacity greater than 32 GB up to 2TB, and the i.MX6SX datasheet mentions that it can support SDXC. So, the processor shall support up to 2TB.
In addition to this, the file system format supported in SDXC is exFAT, so the processor shall support exFAT as well.
One can refer to the below link for reference:
https://www.sdcard.org/developers/sd-standard-overview/capacity-sd-sdhc-sdxc-sduc/
Thanks & Regards,
Ritesh M Patel
1,992件の閲覧回数
sowmiya_a
Thanks for the response.
Then why it is not mentioned in the i.MX6soloX datasheet that MCIMX6X4CVM08AC can support upto 2TB?
