SDMA how to configure ping-pong structure
1,291 次查看
剑明廖
I use sdma to transfer data from ssi,I want to create pingbuf and pongbuf for sdma to receive data,but i don't know how to configure the sdma,who can help me or give me an example???
Thank you very much!
标签 (2)
1,119 次查看
Hi 剑明 廖
I am not sure that this is feasible, however one can loop
sdma structure using bit W: wrap in Buffer Descriptor data structure, description can
be found in pdf document p.6
MX25 SDMA CSPI example
1,120 次查看
Hi 剑明 廖
