I'm trying to generate a MCUXpresso SDK for the i.MX 8M Nano LPDDR4 EVK. I didn't see the board in the configuration menu for the SDK. Did I miss it, or should I just use the i.MX 8M Nano processor to generate the SDK?
In addition, am I correct in assuming the SDK should work with the MCUXpresso IDE once it's generated? Thanks.
Lee Thalblum
Solved! Go to Solution.
You may use the EVK-MIMX8MN (MIMX8MN6xxxJZ).
Regarding MCUXpresso support, please note that the i.MX SDK is not supported by the MCUXpresso IDE, with the exception of the i.MX RT, the toolchains supported are IAR and GCC ARM only.
Aldo.
Aldo.
