SDK_2.4.0_EVKB-IMXRT1050 Dhara reference
1,831件の閲覧回数
yamakatb
Is there a document that describes the Dhara middleware of SDK_2.4.0_EVKB-IMXRT1050?
Also, can this middleware be used as a Nor flash translation layer in a file system?
1,692件の閲覧回数
FelipeGarcia
Unfortunately, there is no document describing Dhara middleware. As you can see this driver is no longer included in the latest versions of SDK, I recommend you to check the following thread for more information: middleware "Dhara" missing from SDK 2.5.0 on RT1052
Sorry for the inconvenience this may cause you.
Felipe
1,693件の閲覧回数
FelipeGarcia
Felipe
