[SD8997] iwpriv private ioctl not supported
john2207
Hi Support,
In our custom board, our i.MX6UL SOC connected with AW-CM276 (SD8997) wifi module with SDIO interface. We are using NXP latest wifi driver/firmware (version : 16.92.10.p218-MM5X16247.p5-GPL-(FP92)) and trying to use the private ioctl's using iwpriv command.
But the private IOCTL's are not supported and getting error as "Interface doesn't accept private ioctl...". Please refer below log and help us on this issue. We also checked our kernel (5.10.9- gatesgarth) config file and confirmed that CONFIG_WIRELESS_EXT and CONFIG_WEXT_PRIV enabled.
root@axon2-imx6ul:~# iwpriv mlan0 version
version (8BE1): Operation not supported
mlan0 Available private ioctls :
version (0001) : set 1 int & get 128 char
verext (0002) : set 1 int & get 128 char
warmreset (0001) : set 0 & get 0
usbsuspend (0002) : set 0 & get 0
usbresume (0003) : set 0 & get 0
txratecfg (0001) : set 1 int & get 1 int
regioncode (0002) : set 1 int & get 1 int
radioctrl (0003) : set 1 int & get 1 int
wmmcfg (0004) : set 1 int & get 1 int
11dcfg (0005) : set 1 int & get 1 int
11dclrtbl (0004) : set 0 & get 0
qoscfg (0007) : set 1 int & get 1 int
wwscfg (000C) : set 1 int & get 1 int
reassoctrl (0009) : set 1 int & get 1 int
txbufcfg (000A) : set 1 int & get 1 int
sleeppd (000D) : set 1 int & get 1 int
authtype (0012) : set 1 int & get 1 int
port_ctrl (0013) : set 1 int & get 1 int
bssrole (0015) : set 1 int & get 1 int
powercons (0016) : set 1 int & get 1 int
htstreamcfg (0017) : set 1 int & get 1 int
macctrl (0018) : set 1 int & get 1 int
thermal (0019) : set 1 int & get 1 int
hotspotcfg (001A) : set 1 int & get 1 int
txpowercfg (0001) : set 16 int & get 16 int
drvdbg (0002) : set 16 int & get 16 int
bcninterval (0003) : set 16 int & get 16 int
getsignal (0005) : set 16 int & get 16 int
deepsleep (0007) : set 16 int & get 16 int
httxcfg (0008) : set 16 int & get 16 int
htcapinfo (0009) : set 16 int & get 16 int
aggrpriotbl (000A) : set 16 int & get 16 int
amsduaggrctrl (0011) : set 16 int & get 16 int
addbapara (000B) : set 16 int & get 16 int
addbareject (001B) : set 16 int & get 16 int
httxbfcap (001F) : set 16 int & get 16 int
hscfg (000C) : set 16 int & get 16 int
hssetpara (000D) : set 16 int & get 16 int
regrdwr (000E) : set 16 int & get 16 int
bandcfg (000F) : set 16 int & get 16 int
inactivityto (0012) : set 16 int & get 16 int
sdioclock (0013) : set 16 int & get 16 int
sdcmd52rw (0014) : set 16 int & get 16 int
scancfg (0015) : set 16 int & get 16 int
pscfg (0016) : set 16 int & get 16 int
memrdwr (0017) : set 16 int & get 16 int
mpactrl (0019) : set 16 int & get 16 int
sleepparams (001C) : set 16 int & get 16 int
dfstesting (0021) : set 16 int & get 16 int
mgmtframectrl (0024) : set 16 int & get 16 int
cfpcode (0022) : set 16 int & get 16 int
antcfg (0023) : set 16 int & get 16 int
indrstcfg (0025) : set 16 int & get 16 int
getlog (8BE7) : set 0 & get 1500 char
deauth (0001) : set 1 addr & get 0
passphrase (0001) : set 256 char & get 256 char
getkey (0009) : set 256 char & get 256 char
associate (0003) : set 256 char & get 256 char
qstatus (0004) : set 256 char & get 256 char
ts_status (0005) : set 256 char & get 256 char
ipaddr (0007) : set 256 char & get 256 char
httxbfcfg (0008) : set 256 char & get 256 char
wpssession (0001) : set 0 & get 12 char
getdatarate (0001) : set 0 & get 4 int
esuppmode (0002) : set 0 & get 4 int
sysclock (0001) : set 64 int & get 64 int
hostcmd (8BF1) : set 2047 byte & get 2047 byte
rdeeprom (0001) : set 16 int & get 256 byte
sdcmd53rw (0002) : set 2000 byte & get 2000 byte
setuserscan (0003) : set 2000 byte & get 2000 byte
getscantable (0004) : set 2000 byte & get 2000 byte
setuserscanext (0005) : set 2000 byte & get 2000 byte
addts (0007) : set 2000 byte & get 2000 byte
delts (0008) : set 2000 byte & get 2000 byte
qconfig (0009) : set 2000 byte & get 2000 byte
qstats (000A) : set 2000 byte & get 2000 byte
pb_bypass (000B) : set 2000 byte & get 2000 byte
START (8BFC) : set 0 & get 0
STOP (8BFE) : set 0 & get 0
WL_FW_RELOAD (8BFD) : set 256 char & get 256 char
weidong_sun
Hello John,
Yes, the iwpriv command of 88W8997 does have this problem.
You can use the mlanutl command to achieve your purpose.
or iw tool can also be used.
Have a good day!
weidong
