SD combo card is not detected in 2.6.35
923件の閲覧回数
swaraj
Hi, I brought a SD combo card, which has Micro SD card reader and wifi device. If i insert micro SD card and insert in the SD slot, its not detecting Micro SD card. But, high speed SDIO wifi is working. When i used same card in 2.6.38, its detecting micro SD card. What is the difference in SD combo card support in 2.6.35 and 2.6.38 kernels. Regards, Swaraj
2 返答(返信)
689件の閲覧回数
iMXAndrew
What wifi sd card are you using?
689件の閲覧回数
swaraj
Its a customized card from Redpine Signals.
