SD combo card is not detected in 2.6.35
1,019 次查看
swaraj
Hi, I brought a SD combo card, which has Micro SD card reader and wifi device. If i insert micro SD card and insert in the SD slot, its not detecting Micro SD card. But, high speed SDIO wifi is working. When i used same card in 2.6.38, its detecting micro SD card. What is the difference in SD combo card support in 2.6.35 and 2.6.38 kernels. Regards, Swaraj
785 次查看
iMXAndrew
What wifi sd card are you using?
785 次查看
swaraj
Its a customized card from Redpine Signals.
