SD card in 1 bit/4 bit transfer mode
1,052 次查看
rkhatal369
Hello Community,
I am working on interfacing sd card with i.MX8MM.
Is there any sample example or documents available for implementing sd card communication in 1 bit or 4-bit transfer mode?
Thank you!
Rohit
1 回复
1,028 次查看
joanxie
what do you mean "communication"? if you mean how to set this, you can refer to the Table 6-42. SD/eSD Boot Fusemap of imx8mm reference manual
