SCU test firmware fails for IMX8QXP
Search instead for
ShivM
We were not able to build SCU test firmware to include the following for IMX8QXP
   CCI
   HDMI
   HDMI Rx
   VT-X
   Build fails for all of the above, showing linker undefined reference error.
   This is because the required object files for the above tests are not supplied by NXP.
   Can you pls let us know how to get these object files?
ShivM
We built using porting vit versioin 1.11.0.
Please see the build log, commands, and others in the attached log file.
joanxie
how did you build scfw_tests.bin? did you build it by command "make qx R=B0 B=mek T=all" ?
ShivM
Our build command is
make qx R=B0 D=1 DL=5 M=1 B=MyBoard T=all
The output of command is attached
joanxie
what error do you get now?
ShivM
We were not able to build SCU test firmware to include the following.
   CCI
   HDMI
   HDMI Rx
   VT-X
joanxie
back to my question, what build error messages do you get? I need detailed your build steps and error messages, I don't find them in your logfile
ShivM
We built using porting kit versioin 1.11.0.
Error log and build log are attached. Its not a build error its SCU test error. Pls refer to attached logs
ShivM
@joanxie
I have provided the info you asked for in above post dated 7-12-2022 can you pls reply.
ShivM
Can you pls reply.
joanxie
how did you build? did you build SCFW porting kit?
