Rx Filter in IMXRT1170 -EVK CAN
331 次查看
smartpavan333
I am using IMXRT-1170-EVK Of SDK example given in /drivers/flexCAN/ping_pong_buffer_transfer.
My requirement is Receiving all ID's on CAN bus?
I configured for Rx Global masking FLEXCAN_SetRxMbGlobalMask(Base, 0x00);
Actually 8 Id's on the CAN bus , but I am receiving only 3 ID's.
Note : Can Id's are 0x124,0x125,0x126,0x127,0x128,0x301,0x308,0x3C0 These are the ID's need to receive.
Can you help me this issue?
1 回复
302 次查看
Miguel04
Hi @smartpavan333
I'm looking into your problem, can you provide me more information please.
how did you configured the MCR[IRMQ] bit?
According to chapter 66.3.8 Rx FIFO:
"If MCR[IRMQ] is negated, then the FIFO filter table is affected by RXFGMASK."
With FLEXCAN_SetRxMbGlobalMask(Base, 0x00); you are changing other registers.
Best Regards, Miguel.
