Running Qt5 from command line on i.MX6 SABRESD
bhaskarsamanatu
Hi all,
Greetings !!!
I am using dual-display on i.MX6 SABRESD, both displays are detected.
and running matchbox-desktop and from there I am running my Qt5-app
But I want to run my QT5-app without matchbox-desktop.
I want to run directly from console command line.
could any body done before ?
please help me to solve this.
thanks for your valuable time.
Bhaskar
Labels (3)
ajithpv
Contributor V
Did you manage to run the Qt5 application through command line? If not, please let me know. I know how to run the Qt5 via X11 backend, if we select fsl-image-qt5.
hernanrodriguez
Could you tell me how I can run QT5 applications in X11 backend? I use fsl-image-qt5 .
Thanks in advance!
Bio_TICFSL
Hi Bhaskar,
If you are running fsl-image-qt5 on your machine, the platform and input plugin need to be specified. different backends require different graphics plugins, please check the BSP user guide document table 29 for graphics plugins for backends available.
Btw, in the default qt image gui you can run apps from command line, such as the qt5everywheredemo-1.0 and you can specified the display output with export command
hope this helps
