Dear All,
I am working on i.MX8QM-MEK with Android 9 Automotive.I am working on Rear View Camera.
I have following issues,
# ISSUE - 1
Rear View Camera view is being shown in full screen in Cold boot. But, Rear View Camera should have a fixed space (I configured in Android side) on screen while booting and post boot.
I don't why resource not given to other Core.
# ISSUE - 2
Sometimes while system is booting, NXP logo loading image is not being displayed (directly opens launcher application). From this screen Rear View Camera cannot be launched. This happens more frequently while we reboot the board and sometimes while we power Off and On the board.
I needs some expert guide.
Thanks & Regards,
Vinoth S,
Hi Vinoth
1. Resource sharing is described in Chapter 4 Resource Management
sc_fw_api_qm_b0.pdf included in SCFW Porting Kit
M4 Core camera example can be found in SDK_MEK-MIMX8QM, folder ..driver_examples/isi
Welcome | MCUXpresso SDK Builder
2. for reboot issues one can recheck datasheet requirement below
i.MX 8QuadMax Automotive and Infotainment Applications Processors
Hi igorpadykov
I need some information.
for discharged to 0 V,
How much time will i.MX8QM board take ?
Thanks & Regards,
Vinoth S,
Thank You Igorpadykov for your reply.
Regarding reboot I found some idea from your input.
Will you please give me some idea for Display configuration in M4 core as well as Other Cores in i.MX8QM-MEK,
How to configure display will adopted for Cold boot as well as Normal android boot (post boot) ?
Vinoth S,
Hi Vinoth
one can look at ..drivers/fsl_mipi_dsi.c in SDK_MEK-MIMX8QM
Thank you Igorpadykov for the reply.
Vinoth S,
