Reset DDRC/DDR PHY for LPDDR3
EvenFlow
Is it possible to reset and re-initialize the DDR controller and PHY at boot?
We would like to first read the LPDDR3 mode register 5 with the DDRC running at 24 Mhz, and then re-initialize the DDRC controller/PHY running at the normal 528 Mhz (using slightly different settings depending on the LPDDR3 detected).
pengyong_zhang
Hi @EvenFlow
Sorry, Now we don't support reset and re-initialize the DDR controller and PHY at boot, In boot process, only support one frequency point boot.
B.R
pengyong_zhang
Hi @EvenFlow
B.R
