Hi Puneeth
1. In case of 8DXL/SXL, byte swapping is not allowed with LPDDR4 but is allowed with DDR3L.
This is due to SoC design limitation, which would prevent to correctly read the mode registers if
the data bytes were swapped. Then, since DDR3L does not support mode register reads, the byte swapping restriction does not apply to it.
2. it is ok
