Request for Documentation on Encrypting SquashFS RootFS with Yocto for i.MX93
528 次查看
udayMouli
I am trying to encrypt my squashfs rootfs for imx93 during build time. I am using yocto
i tried fetching below document but i am unable to
https://community.nxp.com/docs/DOC-342300
can you please help me to point to proper documentation related to encrypting squashfs of rootfs
445 次查看
AldoG
We do not have documentation available for this, but you may use as a reference one of our partners implementation for this kind of use case:
https://github.com/toradex/meta-toradex-security/blob/kirkstone-6.x.y/docs/README-encryption.md
You may create the layer the same way they are using it, so it is indeed possible
https://github.com/toradex/meta-toradex-security/tree/kirkstone-6.x.y
Best regards/Saludos,
Aldo.
4 回复数
479 次查看
udayMouli
I have reviewed section 10.5.5 and would like to implement a similar encryption approach. Our requirement is to encrypt the production-ready SquashFS image during build time in Yocto. However, using /dev/mapper is not feasible since it requires root privileges.
Is there any method or documentation available for integrating dm-crypt-based encryption directly into a Yocto recipe?
446 次查看
AldoG
Aldo.
502 次查看
AldoG
I forgot to mention that you may also check our Linux documentation, i.MX Linux User's Guide Chapter 10 Security & 10.5.5 DM-Crypt usage on i.MX Platforms without CAAM hardware IP
Since i.MX93 does not have have CAAM hardware IP enabled.
Aldo.
