Remap secure bootloader flow chart seems wrong
4,088 次查看
pm_2552
It appears that the Remap flow chart for SBL has some typos and is not the updated one. Can you please provide the correct flow chart?
3,991 次查看
pm_2552
Please check the highlighted part in the above flow chart. I have marked all blocks where Remap is enabled with "++" and where Remap is disabled to "--"
The enable Remap block in the above flow should be before verification and that is indeed the case in the SBL code.
4 回复数
3,992 次查看
pm_2552
4,046 次查看
pm_2552
@kerry zhou Can you please help?
4,055 次查看
hector_delgado
Hi @pm_2552 ,
I hope you're doing well!
What device are you using?
Thank you.
Hector.
4,047 次查看
pm_2552
Hello I am using RT1060 and this are the docs I am referring to: AN13460
