We are developing a hardware system based on i.mx8m nano. I have a question on the RGMII/RMII interface. According to "i.MX 8M Nano Applications Processor Datasheet for Industrial Products":
On page 42:
"For RMII—ENET_TD2 functions as RMII REF_CLK when configured in the ALT1 mode."
On page 43:
"For RMII—SD1_RESET_B functions as RMII REF_CLK when configured in the ALT1 mode."
I wonder in the ALT0 mode which is the REF_CLK signal? Or is there something wrong with this datasheet?
Thanks!
解決済! 解決策の投稿を見る。
There is nothing wrong with the datasheet. It is just that for getting the REF_CLK through either pad you mentioned, it is required to use the ALT1; for ALT0 this would not be possible.
Hope it helps!
BR,
Ivan.
Hope it helps!
BR,
Ivan.
Thank you Ivan.
