Regarding iMX6 fsl-gpu-sdk-2.3
umashankergupta
Dear Sir,
I am using iMX6 based iW-Rainbow-G15D EVM. I compiled GLES2 samples available in DemoApps as per Setup_guide_ubuntu14.04.txt provided by you only.
I tried to run GLES2 Samples on board. But in some applications(Like Blur, DFNativeBasic2D, EightLayerBlend, T3DStreetTest etc.), i got following error :
WARNING: devil image loading not successfull.
ERROR: Unsupported BMP file format.
Please let me know how to resolve this.
Uma Shankar Gupta
Bio_TICFSL
Hi Gupta,
Do know about rainbow, but GLES2 does not ask you about images. you need a library of devil.
umashankergupta
Hi sir,
 Thanks for your response. I tried to build Devil Lib(1.7.8) for iMX6. But i am facing following error
.libs/libIL_la-il_bmp.o: In function `ilFloatToHalfOverflow':
~/devil-1.7.8/lib/./../src-IL/include/il_manip.h:35: multiple definition of `ilFloatToHalfOverflow'
.libs/libIL_la-il_jpeg.o:~/devil-1.7.8/lib/./../src-IL/include/il_manip.h:35: first defined here
.libs/libIL_la-il_bmp.o: In function `ilFloatToHalf':
~/devil-1.7.8/lib/./../src-IL/include/il_manip.h:62: multiple definition of `ilFloatToHalf'
.libs/libIL_la-il_jpeg.o:~/devil-1.7.8/lib/./../src-IL/include/il_manip.h:62: first defined here
.libs/libIL_la-il_bmp.o: In function `ilHalfToFloat':
~/devil-1.7.8/lib/./../src-IL/include/il_manip.h:181: multiple definition of `ilHalfToFloat'
.libs/libIL_la-il_jpeg.o:~/devil-1.7.8/lib/./../src-IL/include/il_manip.h:181: first defined here
collect2: error: ld returned 1 exit status
make[1]: *** [libIL.la] Error 1
make[1]: Leaving directory `~/devil-1.7.8/lib'
make: *** [all-recursive] Error 1
Please let me know how to resolve it.
Uma Shankar Gupta
