Hi Support -Tean,
We have one question regarding datasheet 0f i.MX7D(19 x 19 mm package)'s Vss(AD05).
We would like to confirm 19 x 19 mm package's datasheet information.
Document:IMX7DCEC.pdf(Rev.4) P140
We can not find AD05(or VSS130).
Latest Rev.4's datasheet or the older is same.
BTW,we can refer AD05(or VSS130) by schematics(i.MX7D Sabre-SDB Rev.d) and Pins Tool(V2.00).
If it is a leak, we would like to be modified when updating the datasheet.
Thanks for this information.
I reported about the doc issue to the team.
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
AD05 will be added to the table 101 in the next release of the document.
Yuri.
