Regarding LCDIF_PWM0 of i.MX8QXP
Kazuma_Sasaki
Senior Contributor I
I am referring the Rev. D, 11/2018 of Document Number: IMX8DQXPRM.
ADMA_LCDIF_PWM0 signal is defined in "Table 9-1. Pin Assignments".
it is belong to the LCDIF module. but, I could not find any description regarding to LCDIF_PWM0 into section 16.10 Enhanced LCD Interface (LCDIF).
Could you please teach me how to use the ADMA_LCDIF_PWM0 signal?
Kazuma Sasaki.
Hi Kazuma
this signal is not part of LCDIF module, but part of Audio Subsystem
(belongs to the same subsystem as LCDIF) depicted on
 Figure 16-1. Audio Subsystem High-Level Block Diagram i.MX8DQXP Reference Manual.
Its address is given in Table 2-6. Audio DMA Memory Map, usage in
sect.16.19 Pulse Width Modulation (PWM) i.MX8DQXP Reference Manual.
Note, there are also another LSIO PWMs described in Figure 18-1. LSIO Subsystem.
https://www.nxp.com/docs/en/reference-manual/IMX8DQXPRM.pdf
Hi Kazuma
Kazuma_Sasaki
Dear Igor,
Problem solved.
I found description at your point. Thank you so much.
Kazuma Sasaki.
