I am referring the Rev. D, 11/2018 of Document Number: IMX8DQXPRM.
ADMA_LCDIF_PWM0 signal is defined in "Table 9-1. Pin Assignments".
it is belong to the LCDIF module. but, I could not find any description regarding to LCDIF_PWM0 into section 16.10 Enhanced LCD Interface (LCDIF).
Could you please teach me how to use the ADMA_LCDIF_PWM0 signal?
Kazuma Sasaki.
已解决! 转到解答。
Hi Kazuma
this signal is not part of LCDIF module, but part of Audio Subsystem
(belongs to the same subsystem as LCDIF) depicted on
Figure 16-1. Audio Subsystem High-Level Block Diagram i.MX8DQXP Reference Manual.
Its address is given in Table 2-6. Audio DMA Memory Map, usage in
sect.16.19 Pulse Width Modulation (PWM) i.MX8DQXP Reference Manual.
Note, there are also another LSIO PWMs described in Figure 18-1. LSIO Subsystem.
https://www.nxp.com/docs/en/reference-manual/IMX8DQXPRM.pdf
Hi Kazuma
