Reg: QT version not properly Installed
6,038 次查看
vishvapathi
I am working on QT with IMX Freescale processor and Linux OS. When i select the qmake file from /home/vishva/Desktop/L3.0.35_4.0.0_130424_source/yes/ltib/rpm/BUILD/qt-everywhere-opensource-src-4.6.0/bin
I am getting following warning for QT version in QT creator "QT version not properly Installed, please run make install”
Am i selecting the wrong qmake file??
标签 (2)
4 回复数
5,397 次查看
Rita_Wang
Hi Vishvapathi,
Have you solved your problem?
Best Regards
Dan
5,397 次查看
vishvapathi
Haven't tried yet.. will try and let you know today...
5,391 次查看
vishvapathi
Still i am getting the same error after updating it to 2.7 version
Attached image.. plz check
5,391 次查看
Rita_Wang
Hi Vishvapathi,
It's the problem of QT path. Download latest qt creator from here http://builds.qt-project.org/view/Qt%20Creator/. And make sure you set path to BBNDK in settings.
Best Regards
Dan
