Hi Vladislav,
yes Freescale does support DDR3 reference design. It is done on SDB board. Nevertheless this design is 64bit DDR3 only. We do not have 32 bit reference design for DDR3. There is possibility to use 32bit DDR3 design on validation board, but this is not optimized.
What we support is 32bits LP-DDR2 reference design on SL. SL is for lowest power same like LP-DDR2.
So please consider to use
- i.MX6SL + 32bits LP-DDR2
- or i.MX6DL,i.MX6D or i.MX6Q with 64bits DDR3.
Reference design is using 0402 capacitors, since it is smallest size accepted by Automotive.
/Jiri
