Reduce the temperature of imx6d
1,111 次查看
haitaochen
hello
      If we want to reduce the temperature of imx6d .  what should we do? Now we reduce the Clock frequency of GPU . That we got the desired temperature. But its performance is so bad. Is there have any good way to lower the temperature without sacrificing performance?
标签 (1)
1 回复
1,008 次查看
Yuri
  You may look at section 4 (Reducing Power Consumption) of app note
AN4509 (i.MX 6Dual/6Quad Power Consumption Measurement)
https://cache.freescale.com/files/32bit/doc/app_note/AN4509.pdf
 Perhaps it makes sense to apply heat sink. You may look at app note AN4579
(i.MX 6 Series Thermal Management Guidelines)
http://cache.freescale.com/files/32bit/doc/app_note/AN4579.pdf
Yuri
