Record android system audio on i.MX6 sabre SD board
klldmofashi
     I want to record android system audio output on file. I saw this thread (Record android system audio) talking about this, but it's for i.MX53 and it's talking about alsa. I thought that Android is using tinyalsa, so does tinyalsa support looping the audio out to mic in as alsa do so that we can capture the system sound in such a simple way?
    I searched around and someone said that by using tinymix, I should be able to get some clue. I got the information by the output of tinymix command, but currently I have no idea how to config it. Is there anyone here who has experience on it? Really appreciate it if you could give me some help.
This is the output of the tinymix commnand:
Number of controls: 105
ctl     type    num     name                                     value
0       BOOL    2       Input Mixer Switch                       On On
1       INT     1       MIXINL IN2L Volume                       5
2       INT     1       MIXINL PGA Volume                        0
3       INT     1       MIXINL IN3L Volume                       5
4       INT     1       MIXINR IN2R Volume                       5
5       INT     1       MIXINR PGA Volume                        0
6       INT     1       MIXINR IN3R Volume                       7
7       INT     2       Digital Capture Volume                   108 96
8       INT     2       Capture Volume                           63 63
9       BOOL    2       Capture Switch                           Off Off
10      BOOL    2       Capture ZC Switch                        On On
11      BOOL    1       Capture HPF Switch                       On
12      ENUM    1       Capture HPF Mode                         Hi-fi
13      INT     1       Capture HPF Cutoff                       0
14      BOOL    1       Capture LHPF Switch                      Off
15      ENUM    1       Capture LHPF Mode                        LPF
16      INT     2       Sidetone Volume                          0 0
17      INT     2       Digital Playback Volume                  96 96
18      BOOL    1       DAC High Performance Switch              Off
19      BOOL    1       ADC High Performance Switch              On
20      INT     1       Beep Volume                              0
21      INT     2       Headphone Volume                         0 0
22      BOOL    2       Headphone Switch                         Off Off
23      BOOL    2       Headphone ZC Switch                      Off Off
24      INT     2       Headphone Aux Volume                     7 7
25      BOOL    2       Headphone Mixer Switch                   Off Off
26      INT     1       HPMIXL IN4L Volume                       7
27      INT     1       HPMIXL IN4R Volume                       7
28      INT     1       HPMIXL MIXINL Volume                     1
29      INT     1       HPMIXL MIXINR Volume                     1
30      INT     1       HPMIXR IN4L Volume                       7
31      INT     1       HPMIXR IN4R Volume                       7
32      INT     1       HPMIXR MIXINL Volume                     1
33      INT     1       HPMIXR MIXINR Volume                     1
34      INT     1       Speaker Boost Volume                     3
35      BOOL    1       EQ Switch                                Off
36      INT     2       EQ1 Volume                               12 12
37      INT     2       EQ2 Volume                               12 12
38      INT     2       EQ3 Volume                               12 12
39      INT     2       EQ4 Volume                               12 12
40      INT     2       EQ5 Volume                               12 12
41      BOOL    1       VSS Switch                               Off
42      BOOL    1       HPF1 Switch                              Off
43      BOOL    1       HPF2 Switch                              Off
44      BOOL    1       HD Bass Switch                           Off
45      INT     2       Speaker Volume                           0 0
46      BOOL    2       Speaker Switch                           Off Off
47      BOOL    2       Speaker ZC Switch                        Off Off
48      BOOL    2       Speaker Mixer Switch                     Off Off
49      INT     1       SPKOUTL Mixer IN4L Volume                7
50      INT     1       SPKOUTL Mixer IN4R Volume                7
51      INT     1       SPKOUTL Mixer MIXINL Volume              1
52      INT     1       SPKOUTL Mixer MIXINR Volume              1
53      INT     1       SPKOUTL Mixer DACL Volume                0
54      INT     1       SPKOUTL Mixer DACR Volume                0
55      INT     1       SPKOUTR Mixer IN4L Volume                7
56      INT     1       SPKOUTR Mixer IN4R Volume                7
57      INT     1       SPKOUTR Mixer MIXINL Volume              1
58      INT     1       SPKOUTR Mixer MIXINR Volume              1
59      INT     1       SPKOUTR Mixer DACL Volume                0
60      INT     1       SPKOUTR Mixer DACR Volume                0
61      ENUM    1       SPKOUTR PGA                              DAC
62      ENUM    1       SPKOUTL PGA                              DAC
63      BOOL    1       SPKOUTR Mixer DACL Switch                Off
64      BOOL    1       SPKOUTR Mixer DACR Switch                Off
65      BOOL    1       SPKOUTR Mixer MIXINL Switch              Off
66      BOOL    1       SPKOUTR Mixer MIXINR Switch              Off
67      BOOL    1       SPKOUTR Mixer IN4L Switch                Off
68      BOOL    1       SPKOUTR Mixer IN4R Switch                Off
69      BOOL    1       SPKOUTL Mixer DACL Switch                Off
70      BOOL    1       SPKOUTL Mixer DACR Switch                Off
71      BOOL    1       SPKOUTL Mixer MIXINL Switch              Off
72      BOOL    1       SPKOUTL Mixer MIXINR Switch              Off
73      BOOL    1       SPKOUTL Mixer IN4L Switch                Off
74      BOOL    1       SPKOUTL Mixer IN4R Switch                Off
75      ENUM    1       HPOUTR PGA                               DAC
76      ENUM    1       HPOUTL PGA                               DAC
77      BOOL    1       HPMIXR DACL Switch                       Off
78      BOOL    1       HPMIXR DACR Switch                       Off
79      BOOL    1       HPMIXR MIXINL Switch                     Off
80      BOOL    1       HPMIXR MIXINR Switch                     Off
81      BOOL    1       HPMIXR IN4L Switch                       Off
82      BOOL    1       HPMIXR IN4R Switch                       Off
83      BOOL    1       HPMIXL DACL Switch                       Off
84      BOOL    1       HPMIXL DACR Switch                       Off
85      BOOL    1       HPMIXL MIXINL Switch                     Off
86      BOOL    1       HPMIXL MIXINR Switch                     Off
87      BOOL    1       HPMIXL IN4L Switch                       Off
88      BOOL    1       HPMIXL IN4R Switch                       Off
89      ENUM    1       STR                                      None
90      ENUM    1       STL                                      None
91      BOOL    1       MIXINR IN2R Switch                       Off
92      BOOL    1       MIXINR IN3R Switch                       Off
93      BOOL    1       MIXINR PGA Switch                        On
94      BOOL    1       MIXINL IN2L Switch                       Off
95      BOOL    1       MIXINL IN3L Switch                       Off
96      BOOL    1       MIXINL PGA Switch                        On
97      BOOL    1       INPGAR IN1R Switch                       On
98      BOOL    1       INPGAR IN2R Switch                       Off
99      BOOL    1       INPGAR IN3R Switch                       Off
100     BOOL    1       INPGAR IN4R Switch                       Off
101     BOOL    1       INPGAL IN1L Switch                       On
102     BOOL    1       INPGAL IN2L Switch                       Off
103     BOOL    1       INPGAL IN3L Switch                       Off
104     BOOL    1       INPGAL IN4L Switch                       Off
Yao
Tags (3)
Wlodek_D_
Senior Contributor II
Thank you for your post, however please consider moving it to the right community place (e.g. i.MX Community ) to get it visible for active members.
For details please see general advice Where to post a Discussion? (https://community.freescale.com/docs/DOC-99909 )
Thank you for using Freescale Community.
