Reboot recovery issue in Android N7.1.1
1,616 次查看
charleshuang
Senior Contributor II
Hi NXP Team
    I test recovery function in imx6q demo board in Android N7.1.1.
When I send command "reboot recovery" in debug port, the system can not enter recovery.
Do you have any advise?
标签 (2)
标记 (1)
1,386 次查看
JayTu
You should use factory reset in Android settings. Reboot recovery is not mandatory for android.
1,386 次查看
Rita_Wang
And I will test it on my board and then give you my resuilt.
1,386 次查看
Rita_Wang
Here you can try combo-key -- "power + volume down" during boot-up, to see if the system can enter recovery mode correctly.
