Reboot and reset not working on IMX8MM carrier board
FOC
Hi everyone,
I'm working on a custom IMX8MM carrier board and I'm using variscite SoM module. When I try to write reboot command in linux terminal system doesn't restart and this error occurs when I press the reset button but in the UBOOT terminal the reset circuit and the reset command works. I attached terminal outputs and reset schematic.
Best Regards
