Hi Igor,
Thanks for your quick reply.
Do you know why it set default mode instead of fault mode? It seems fault mode get better reliability, don't it?
BRs
Mark
Solved! Go to Solution.
You are right, the PMIC fault mode is intended for most reliable applications.
Yuri
Yuri
