I am using i.MX6 board with latest kernel 4.1.15, facing issue with that board, the problem is board randomly rebooting, whenever insert the SD to boot the board,board is booting randomly, there is a error coming that below,
ubuntu@imx6qsdl-utopic:~$ [ 22.485237] Unable to handle kernel paging request at virtual address 00002e04
And I have checked with kernel source also.i could not fine the issue , so Can you please help me to resolve the issue.
Thanks in Advance.
Mathan
已解决! 转到解答。
new calibration coefficients found from ddr test should be entered to uboot *.cfg file
uboot-imx.git - Freescale i.MX u-boot Tree
Hi Igor,
According to that,RAM configuration everything is fine ..
Just now I noticed that, some of the time board getting reboot after Login with in 15 to 20 mints ..
is that issue is new things or related this RAM issue ??
Please clarify it.
Thanks.
Mathan
Hi Igor,
I had tried last one week, even we tried with DDR calibration test with various cpu frequency, I could not.
For your post make us to resolve it.
Thank you so much for solution.
Mathan
I was seeing a similar issue on my board. Here's what I would suggest.
If you're seeing instability, meaning unstable all the time, and not related to a specific action, then you want to check if your DDR timing/calibration values are suitable for your board. https://community.nxp.com/docs/DOC-105652
The other possibility is your kernel or board may have CPU_FREQ related issues and you may want to investigate whether disabling that causes the instability to cease.
Hope that helps.
