Thanks for the info, I see the option now.
Is it possible to define both an SDRAM and SRAM SEMC configuration in the same .mex file?
When I try to add an additional Register Initialization component (already had an SEMC peripheral SDRAM config), or two components - one for each of SDRAM and SRAM - I get an error about the peripheral being used in multiple instances.
Matt
