On some processors (e.g. Vybrid VF6), it is possible to use the RTS signal for RS485 transceiver output control. I'm struggling trying to do the same on i.MX6SX. It seems to be achievable with the CTS signal though. Is it possible to configure the RTS pin for this functionality?
Solved! Go to Solution.
Hi kubiznak_petr
unfortunately it is not possible only switch RTS<->CTS in software.
<dummy>
Hi kubiznak_petr
one can consider control of DCE/DTE mode described in
Figure 65-2. UART external signals to module signals routing with respect to DCE/DTE mode
i.MX 6SoloX Applications Processor Reference Manual
Hi igor,
Thanks for your reply. That looks promissing but then the issue would be that the RX/TX signals would be switched too, right? Or is it possible to only switch RTS<->CTS in software?
Hi kubiznak_petr
