RAM for M7 core of iMX8MPlus
430件の閲覧回数
ReshmaRoy
For iMX8MPlus SoC , does it require separate RAM memory for M7 core ? Or is there a internal SRAM for M7 core?
418件の閲覧回数
Chavira
Hi @ReshmaRoy!
Thank you for contacting NXP Support!
The M7 core does not require an separate RAM.
You can run the M7 core in TCM (tightly coupled memory ) integrated in the chip or if you require more RAM you can run in the external DRAM of the A core.
I attached the Getting Started with MCUXpresso SDK for EVK-MIMX8MP, please check the chapter 6 (Running an application by U-Boot) to learn how to run an application in TCM or in DRAM.
Best Regards!
Chavira
