R10.4 c_patch problem
1,802 次查看
charleschang
I follow user guild, when I run c_patch, it want me to confirm that it need to remove 3 folder in first, includes kernel_imx,
I say yes, then It compain about there are not files in kernel_imx.
So I modify the "baseversion" , about the kernel_imx entry, chage the "NEW" to "CHANGE".
It works!
标记 (2)
1,443 次查看
charleschang
something wrong in the file: baseversion.
when you run c_patch , it failed on some project,
for example, the kernel_imx project,
you need to modify the "baseverion" file, change the entry of kernel_imx from "NEW" to "CHANGE"
muthe srinivas said:
can you explain it in detail.please?
I am getting problem with c_patch  for the same R10.4 can u explain it again in detail,,,plz!
1,444 次查看
charleschang
1,443 次查看
muthesrinivas
