Question, i.MX6Solo SD port feature
Aemj
Dear team,
I would like to ask a quick question about SD module of i.MX6Solo.
In case of using i.MX6S with two SD card port, can I understand that one port can support SDXC while the other port can support SDHC only?
My customer found the description as below in your WEB site.
“Expansion Ports; 3x SD/MMC 4.4, 1x SDXC”
Miyamoto
joanxie
refer to  the refence manual, the uSDHC module is capable of SDXC, so all 4 SD interfaces should be capable. The limitaton is which one's has the signals muxed out.   Whether sdxc is supported is a feature of the board. For instance, on the SABRE-SD there is no support for SDX. Whereas on the SABRE-ARD, SD3 is capable of SDXC.
Aemj
Hello Joan,
Sorry for my late response. But let me clarify my understanding.
Can I understand that sometimes user cannot assign multiple SD ports on their own board due to IO-MUX?
Miyamoto
