Question, how to handle SATA under i.MX6Q AndroidBSP4.0
941 次查看
Aemj
Hi All,
My customer is trying to implement a SATA shutdown function into their application software for their i.MX6Q board.
Their software is developed based on your AndroidBSP4.0.
The function they need to implement is to issue STANDBY IMMEDIATE(0xE0) command to ssd device connected to i.MX6Q SATA port.
If your AndroidBSP4.0 already has such API or function in it, could you show me how to use the function?
Miyamoto
标签 (1)
2 回复数
854 次查看
Aemj
Hi team,
I am still waiting for your reply.
Miyamoto
854 次查看
SergioSolis
Hello Miyamoto,
It is not implemented in our BSP, you would need to implement it on your side. Are you booting from sata or using SD and sata as extra storage?
