Had anyone run weston extended mode for dual display successfully on iMX8MQ EVK?
Currently, I could only run weston on only one display (on drm/card0 or drm/card1) without extended mode support. It looks like the "[output] name" field is ignored by weston. It always uses "drm/card1" if I don't select card by "--drm-device=cardX" parameter.
Brian
Solved! Go to Solution.
 Rita_Wang
			Rita_Wang
		Hi Brian,
I have confirmed it for you that the default BSP support weston run on one display and another display for video play.
About the dual display weston we have no application on this, so sorry.
Have a nice day
Rita
 Rita_Wang
			Rita_Wang
		Hi Brian,
Have a nice day
Rita
 Rita_Wang
			Rita_Wang
		Hi Brian,
Our default BSP support, about the dual display I will need confirm it with our expert team, and then give you reply.
Have a nice day
Rita
