delete
3,804 次查看
Anonymous
不适用
3,592 次查看
joanxie
I think I already tell you how to read the higher 64bits, the command is general for other processors which only have 64bits, and I also confirm from internal team that ROM API needs to read 128bits to operate, so I suggest that you read 128bits, if you only read 64bits, I couldn't guarantee that
10 回复数
3,793 次查看
joanxie
refer to the reference manual, lower 64bits from 0x420[10:0]-0x430[11:31]and higher 64bits from 0xE00-0xE10
3,784 次查看
Anonymous
不适用
delete
3,778 次查看
joanxie
the higher 64 bits thus bank 40 word 0 and bank40 word1.
3,761 次查看
Anonymous
不适用
delete
3,755 次查看
joanxie
since this soc uses 128bits as UID, try to use 128bits
3,735 次查看
Anonymous
不适用
delete
3,705 次查看
Anonymous
不适用
delete
3,672 次查看
joanxie
I think already replied to you, if you need repeat gain, for imx8mp, ROM API read 128bts  as UID
3,638 次查看
Anonymous
不适用
delete
3,593 次查看
joanxie
