Thanks in Advance for your support.
Thanks & Regards,
Rameshkumar
Hi Ramesh
-DRAM_SDCLK_0 ,1 connections are correct (these pads outputs identical clock).
-you are right, 10K ohm pull down resistors will change signal, however
one can increase drive strength of these signals and use ibis modelling
if necessary.
-MMPF0100F6AEP sequence will not cause problems.
Dear Igor,
Thanks for your quick response its very helpful.
I would like to discuss our Software team about IBIS modelling and plan for External Hardware IO-buffers if its really require. Any further more queries we will get back to you soon.
Thanks & Regards,
Rameshkumar
