Qtwayland failure due to hardware Integration Layer VSP2 - iMX8qxp
190 次查看
Ram2
HI NXP Team,
                   " VSP2 hardware layer integration "
 Qt Wayland Compositor Layer Plugins:
  VSP2 hardware layer integration ..... no
| ERROR: Qt Gui has been built without 'wayland' feature. This feature is required for building Qt Wayland Client.
| CMake Error at /mnt/yocto_builds/lynx_qt_6_8_3/build-wayland/tmp/work/armv8a-poky-linux/qtwayland/6.8.3/recipe-sysroot/usr/lib/cmake/Qt6/QtBuildInformation.cmake:220
| -- Configuring incomplete, errors occurred!
| WARNING: exit code 1 from a shell command.
We are trying to migrate Qt6.5.3 to Qt6.8.3 in yocto[ Nanbield] , so qtwayland is failing due to above mentioned in ImX8qxp
1 回复
155 次查看
Bio_TICFSL
Qt is upgraded to 6.5.0. in the last yocto Software from NXP. You have to wait for next release.
