Qt5 segmentation fault with EGL
1,765件の閲覧回数
rakesh3
Hi team,
I am using the imx6qsabresd board with kernel version 5.10 and using the imx-gpu-viv_6.4.3 version vivante GPU.
I am getting the Segmentation fault while running the Qt5 GPU application.
As per the given link https://community.nxp.com/t5/i-MX-Processors/QT5-4-eglfs-hellogl-es2-Segmentation-fault/m-p/423948
I have the correct version of GPU vivante 6.4.3 with kerenel version 5.10
How to confirm about the correct user mode libraries imx-gpu-viv compatible for X11 display ?
From where i can get those libs ?
Please help me to solve this issue !
Rk
ラベル(4)
タグ(2)
1,744件の閲覧回数
Bio_TICFSL
X11 don't work with 5.x kernel and up, you need to have 4.x kernel version.
1,721件の閲覧回数
rakesh3
Thanks for reply,
But we have received the prebuild libraries for GPU from NXP, I have attached the libs.
Please have a look into those libs and give your suggestions on this.
Rk
