Qt4.8.6 compilation issue using toolchain for ARM
2,246件の閲覧回数
Subodh_K
Hi all,
I am compiling Qt 4.8.6 package  for ARM from Toolchain (arm-poky-linux-gnueabi-) . I have made changes in configuration file qmake.conf as per my need
# qmake configuration for building with arm-poky-linux-gnueabi-g++
include(../../common/linux.conf)
include(../../common/gcc-base-unix.conf)
include(../../common/g++-unix.conf)
include(../../common/qws.conf)
# modifications to g++.conf
QMAKE_CC                  = arm-poky-linux-gnueabi-gcc
QMAKE_CXX                = arm-poky-linux-gnueabi-g++
QMAKE_LINK                = arm-poky-linux-gnueabi-g++
QMAKE_LINK_SHLIB     = arm-poky-linux-gnueabi-g++
# modifications to linux.conf
QMAKE_AR                  = arm-poky-linux-gnueabi-ar cqs
QMAKE_OBJCOPY       = arm-poky-linux-gnueabi-objcopy
QMAKE_STRIP             = arm-poky-linux-gnueabi-strip
QMAKE_LFLAGS             = -lts
QMAKE_INCDIR             = /home/subodh/tslib_arm2/include/
QMAKE_LIBDIR              = /home/subodh/tslib_arm2/lib/
QMAKE_CFLAGS_RELEASE      =   -O2 -march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=softfp
QMAKE_CXXFLAGS_RELEASE  =   -O2 -march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=softfp
load(qt_config)
And for configuring  I am using the command as:
./configure -embedded arm -xplatform qws/linux-arm-g++ \
-qt-mouse-tslib -qt-gfx-linuxfb \
-little-endian -prefix-install -depths 16,18,24 -optimized-qmake
for Build :
make
sudo make install
During configuration i am getting  issue like
The tslib functionality test failed!
You might need to modify the include and library search paths by editing
QMAKE_INCDIR and QMAKE_LIBDIR in
/home/subodh/qt-everywhere-opensource-src-4.8.6/mkspecs/qws/linux-arm-g++.
1,182件の閲覧回数
peterchiu
Hi Subodh Kant
Maybe your can try your filesystem path (lib & include) in QMAKE_INCDIR & QMAKE_LIBDIR.
